KevinToledo
- Jul 12, 2017
- 9
Bought a mint, low hour 2004 Glastron SX195 with 220hp VP 5.0 GL-E and SX-M 1.6 drive. Water tested for about a 1/2 hour, all was fine. I took the boat the next week after purchase to a local VP authorized dealer for outdrive service, impeller, oil change, etc. Got the boat back, 1st time on lake above 4k RPM the temps were coming up. After about 2 min above 4k RPM, got close to 200 degrees and the alarm came on. Slowed down right away and the alarm went off and temps backed down to about 180. When I ran it back up, temps started rising again. Took it back to marina and they water tested boat and said it was fine at first then on way back in, temps were going up and they suggested a thermostat. After they replaced the thermostat and water tested, they said that the temps were still coming up. They allegedly ran clear hoses off of the pump and said that there was a lot of air in the big hose between the circulating water pump and the thermostat housing. Then they inspected both sides of the block and saw what they are alleging a "crack in the block" and that this must be what the problem is. There is no water in the oil, the boat runs great, just is getting hot now at higher RPM, and this crack looks more like a crack in the paint not a thru crack in the block. Thoughts? I will be getting a second opinion.
