Fxportapot
- Jul 25, 2015
- 19
I have a 2000 seaswirl 4.3gl w/ penta sx. We were on the lake this evening (be jealous 82 degrees and sunny here in NC). I pulled the boat up to about 4k RPM and it started making some knocking, oil pressure was at about 40psi, backed it down to around 3k and all was well. Gradually the oil pressure kept dropping so we called it a day. Pulling into the ramp oil pressure was 10 or less at idle and the engine was making some noise, like it wasn't gettkng oil. Once home the oil level is perfect. Oil pump? Clogged something or other?
I had something similar happen to our 5.3 chevy and it was a bad oil filter with a malfunctioned back flow valve.
