Tommy Two Stroke
- May 14, 2009
- 65
I wanted to share the mechanical details of my recently completed retrofit of a Sierra 18-5176 OMC style ignition coil to an Eska 7.5hp outboard, in case anyone could use this info. This outboard has the infamous under-flywheel solid state trigger module and the no longer available ignition coil mounted to the gas tank. The pics show the box beam stock that I fashioned into a bracket to accept the Sierra coil. Nuts for the coil attaching screws are epoxied to the inside of the bracket for captivation. The bracket is held to the gas tank with screws, and I had to drill one additional hole in the tank and enlarge one of the holes that was used to mount the old coil. Bottom line: if you have one of these outboards with a failed original coil, it is possible to retrofit a widely available Sierra 18-5176 coil to the outboard using this method.
