dirtdevilnc
- May 27, 2011
- 18
hi all, I am looking to purchase a new to me Maristar 210 VRS. It is outfitted with the GM Corvette branded LT1 and Hurth ZF V-drive. Overall it’s in good shape with low hours. The owner is currently running ATF and I understand sometime in the early 2000 time frame the transmission manufacturer recommended moving to 15w40 to quiet perceived transmission rattling noises from owners, newer boats outfitted with this trans noted 15w40 in the owners manuals.
My question is it seems to have a transmission whine when under way. I have confirmed that when the engine is in neutral and revved the engine there is no wine so it’s not the alternator or impeller.
I currently have an older centurion v drive with a velvet drive transmission which is barely unnoticeable as far as sound goes.
Attached is a link to a quick video I shot, does this seem abnormal or is it just a different transmission which makes different sounds?
thank you.
https://youtu.be/O5TbW8U9aKg
thank you.
