ACon977
- Nov 21, 2017
- 759
Hey all,
I have an old 1987 Ski Centurion with an inboard DD 351W in it. Before I purchased the boat, it had sat for upwards of 5+ years, although the engine seems to be in decent shape since the engine cover stayed together. I currently have a rebuild thread where I had it gutted to the hull and am now rebuilding it from the stringers up. Now that I am to the point of mounting the engine I have made some attempts to get it running, but so far have been running into issues.
Mainly the person who owned the boat before me decided to do a bunch of modifications to it. But I'm not sure what in all that entails. From what I can see they replaced the OEM carb with a Holley, Point distributor with an HEI system (no markings or SN on it for me to see what kind), new wires and plugs?
My original inspection of the engine involved taking the valve covers off, rotating the crank manually, testing the starter (ended up replacing), and looking into each cylinder with a boroscope to check the piston heads and cylinder walls. I also did a cold leak and compression test, but honestly, that didnt tell me much.
Now that I'm trying to get the engine running everything seems to be rotating fine, but Im curious about my distributor since Scott Danforth pointed out it could be a GM and not a marine version, in addition I am not getting a spark from any of the plugs.
Looking for some assistance on what I should be checking to get this firing up. I've attached what images I have.
