mrbiggdaddy
- Sep 29, 2012
- 4
after 6 years, got my '78 galaxie tri-hull out of storage. Decide it was worth way more than the 800-900 I might could get selling her. So I got her cleaned up. Got her tuned up, new plugs wires, dist cap, points, fuel tank flushed, time for oil change....I pumped out 5 qts of water and a quart of oil sludge out of it ----I couldn't believe it. I had accidentally flooded the inside rinsing her out..left the hose running and drain hole got clogged. So I figured water must have got in as the water level got all the way over the oil pan..half way up the block level and was that way for at least an hour before being discovered. So I put new oil in, ran it with muffs on, sucked out basically good oil with no water. I figured it would be milky from running with water muffs if there was internal compromise to crankcase. So I changed oil filter, put new oil back in it. Got it running great, oil was clean after idling 30-40 minutes on muffs....soooo Took it out last Sunday for sea test, and ran fine, but didn't run long as I didn't check sterndrive oil levels, didn't trust myself. Bought 9.9 HP 4-stroke Honda kicker and it bracket mounted. Then yesterday, I had the sterndrive oil levels topped off and got trained how to do same, then invested $200 in new prop and hubkit. Fixed up trailer lights. Bought tubes and lures. Told the boys to buckle up their fishing belts for Saturday Lake St. Clair smally, walleye, and tubing expedition. Did an oil level check after hooking boat up at my shop......and it's chocolate milk. water in my crankcase!!!!!! so the water I pumped out wasn't from me flooding the boat...it was from my sea-test last Sunday. cracked block? my neighbor who knows something thinks the crack might be in the upper manifold to allow water into my crankcase? is it part number one in this drawing? If not what. Anyone with a parts engine for me? HELP?! Please and many thanks in advance.
Ray
Ray
