I need to replace my lower control cable thus I need to separate the upper gear box from gimbal. I have removed the tilt bolt supported the piston and the 6 bolts. I've manhandled and wiggled it and can only get maybe 1/4 inch separation. Is there a hidden bolt or a special technique other than just wiggling. The bottom portion is giving the hardest time. Thx
