slester1969
- Nov 1, 2017
- 2
Boat sat all season winterized with the stern drive unit down with no problem. Out of storage a few days later, stern drive up, it started leaking gear oil from behind the prop. Oil is not milky so I'm assuming no water in the housing. I obviously haven't hit anything so guessing a prop shaft seal just went bad.
Assuming there are no damaged parts, what seals and/or o-rings will I need to fix this? I do have a shop manual. Thanks in advance.
1990 5.8L OMC Cobra
1990 5.8L OMC Cobra
