cumminscruiser
- May 9, 2019
- 9
Had dry rot stringers that are repaired, I placed the motor back in and started to install the outdrive but to won’t go in all the way. It comes to a hard stop 3/8” from seating. I don’t remember seeing dry rot at the transom but I’m thinking that I tightened those bolts and squeezed 3/8” of dry rot now the outdrive coupling shaft is too long. I did double check the P/N on the coupling and it is correct. Thoughts?
