PS any follow up on this? Got it back together? Even if you do it yourself it's not a hard job. The trick is to use a little gasket sealer on the ends of the gaskets to keep them in place and keep them from moving around when you set the intake in place. Then the next lil trick is getting the distributor clocked correctly.
I've been running mine a lot lately. With the new heads it runs better naturally and they brought back some of the HP lost due to wear as the engine got older. Also, the center riser exhaust set up breaths better than the more restrictive OE batwings since the elbow outlet is 4" instead of 3.5". With the new heads it runs cooler and the exhaust system also runs cooler, after coming off plane my batwings used to peak at about 135*, these just hit 110* under the same conditions, probably because the cooling passages are much larger. A good upgrade for these old pre-vortec OMCs.
