Just recently purchased my first boat. It's a 1990 Sunbird Corsair 185. I had the muffs on and started the motor, the throttle accidentally got hit to run wide open and I quickly got it back to neutral, then the motor died and wouldn't crank. I used a multimeter and determined the slave solenoid above the starter on the block had went bad, I replaced it and now it's cranking, but none of the pulleys on the front or the crank is turning. I tried using a screwdriver in a spark plug wire to see if it would arc over to the block and got nothing. The bottom flywheel cover was removed when I bought the boat, the flywheel is spinning when I crank it but the crank pulley isn't turning on the front of the motor. I did look and find what looks to be 3 flywheel studs laying under the motor. The motor is 302BMRPWS. I thought maybe the flywheel studs could have sheared, the crank could have broke, or the keyway on the crank might have sheared. Any help would be greatly appreciated.
