slowhand35
- Jul 6, 2012
- 17
I recently purchased a pretty rough1964 Johnson deluxe 17 ft. Boat without the factory trailer, missing the external outdrive and has a stuck factory 225 v6 Buick motor that is also missing parts.
I'll be posting in other sections with questions on those.
For now, I have a couple questions about the engine.
I'm a fair hand at mechanics, so rebuilding the engine isn't a problem.
My questions, this 225 v6 was basically the same block for many years until the bell housing mount was changed.
Does anyone know for certain through personal experience if one of these v6 engines from a later year, say mid 1980's for example, can be stripped of the intake with fuel injection and other modern parts that require the computer, ECM, etc. and replace them with the old factory intake with carb, distributor, etc. Basically using the core block to build and replace the old one ?
I'm asking because it may be cheaper ($100) and easier for me to pick up a good used motor of this type in my normal circles rather than starting with an old block with rusted cylinders.
Second question,
Is it still possible to find the omc exhaust manifold and other water pumping parts for these old motors ?
The one manifold that's still there is rusted and split down the middle, I have no idea what the other parts were or how they were assembled.
I have the Seloc outdrive manual for 1964, no real pictures of my engine or boat, but great overall info.
Thanks for any help
Second question,
Thanks for any help
