Anyone else still following this thread. I have a bad FWD spring, I think, I can put 12v to the wd and no click, when I hit the reverse wire with 12v it clicks. I have the lower removed, swivel housing off the top of the lower unit, the shaft that the prob goes on out of the housing with about half of the shaft, problem is it's the reverse end.
Is there a way to get the FWD end of the shaft out without the Magic Socket, thanks a million for that part number BTW, to hold the input shaft splines and removing that nut?
Any other magic things I need to know, I'm trying to get this done to catch the last of the Bonito running off of Dana Point, maybe catch one last Mako this season.
Thanks in advance
Tom
Thanks in advance
Tom
