platinumedge
- Aug 12, 2018
- 93
Hello to All,
I've been around boats for many decades, have much experience with automobile repairs, and purchased my first boat last week. I have been reading many of the pertinent posts on this website, over the past couple of weeks, and can obviously see that there is much to learn, AND much to be offered here!
I purchased a 1994 Four Winns Horizon 215. It has a 5.8L EFI engine, according to the stickers. It was sitting outside for 3-5 years, on a Four Winns trailer, but completely exposed to the elements (in Maryland). It's actually not in terrible condition: the bow cabin doesn't smell bad, most of the seat cushions/vinyl are in decent shape, the electrical accessories turn on when attached to a power source.
When I attached a battery to it, the accessories came to life, but when I turned the key there was nothing - no clicking, no action. The seller (a previous marina owner, who acquired the boat through some sort of default process) said he has never seen the boat in operation, but had his mechanic manually turn the crankshaft BOTH ways, but just a few degrees. His recommendations were to:
A few questions:
Thanks so very much, in advance.
Cheers,
-- Jeff
- Pull the plugs and put several squirts of 10W-30 into each cylinder, then manually turn the crankshaft at least two revolutions in each direction
- Replace the fuel
- Replace the water pump impeller
A few questions:
- The stranded cable in the (manual) winch sheared. Can I just buy new cable? Or do you recommend replacing the entire winch? Where should I go to find the cable, or the winch?
- How does one drain the fuel from this boat?
- Do you have recommendations as to which battery type/size? And where to purchase?
- Where can I purchase a water pump impeller for this engine/outdrive? What specifications are needed to get the correct part?
- Is there some documentation that describes how the canvas/clear covers go together? There are two tops, 2 clear sides, 1 clear back (multiple pieces), and 2 canvas sides.
- There is no spare tire/wheel for the trailer. Where do you guys/gals recommend I go to acquire the correct spare? And necessary attachment hardware?
- For starting testing: Should I connect the battery to the terminals (I have a feeling there may be some wiring issues)? Or directly to the starter solenoid? (I really just want to hear the engine run for a few seconds, right?)
- Lastly: I would honestly love to hear additional recommendations/comments/inputs/ideas/suggestions as to how to bring this beautiful craft "back to life" and get her running smoothly!
Cheers,
-- Jeff
