JBtwist
- Jul 22, 2018
- 58
Hey Everyone,
First post here. We just bought a 1986 fabuglas commodore 19' boat with an OMC sterndrive. We are having some inconsistency with the tilt motor engaging. The solenoid is clicking every time, but the motor isn't engaging every time. I put a meter on the wire coupler, but it's so inconsistent that I'm having a hard time determining if it's the isolated to the solenoid. If I jumper the solenoid, I can kick it on every time...so I think it's probably that part.
My question is - is there a better way to determine if that issue is specifically that part? I'm kind of an amateur with this stuff, but I'm fairly mechanically inclined.
Additionally, I drained and replaced the oil in the worm gear for that tilt motor and it had a ton of water in it, about 40% oil, 60% water. I've read that people have taken it apart and packed it with grease instead of oil. Is that something I should do? When I filled it up with oil, there is oil leaking alongside the gear...about a teaspoon overnight.
I'm not a professional...just a guy trying to learn how to fix things up myself. Thanks in advance for your help!
