1 or 2 gallon gas tank available?
simplystressed
Hi all, is there a 1 or 2 gallon gas tank on the market for outboards? I have limited space and would prefer this size for a 4-6hp motor.
Thanks!
Bob_VT
Re: 1 or 2 gallon gas tank available?
Thanks!
There are 3 gallon tanks available
pootnic
I know some 4hp motors have a fuel tank hooked right with them,not sure about a 6hp.
Can't get much smaller then that.
nwcove
there is a setup available......cant remember what its called tho, that will let you hook you motor up to almost any jerry can of fuel. just plug in as you would to a normal oe tank. hopefully someone will chime in with the info.
nwcove
found an old email......bkk enterprises. adapt-a -can.
