S. S. Lanier
- Jul 31, 2019
- 36
Hello all,
This will be our first time to winterize our motor. I've read quite a few threads and believe I have the basics of it, but I'm wondering if there's anything I'm missing. Is there anything else I need to do other than:
1) add stabilizer to fuel and run it through the motor for around 10 minutes with muffs on
2) spray fogging oil in carburetor till engine stalls
3) remove spark plugs and spray fogging oil, replace and turn flywheel
4) drain and replace lower gear unit oil (I believe there's a specific oil I need to use?) type C?
Thank you for any help you can give.
