I was concerned that the fiberglass was not meant to hold a person's weight (hence the need for a floor elsewhere) and that I'd go crashing through the bilge to the trailer below if I tried.
Unfortunately, I can fit in the bilge, but not without draping myself over the backseat. Taking the backseat out seems like a ton of work for just replacing a bilge pump, but that may be where I need to go.
Very helpful info guys - I was concerned that the fiberglass was not meant to hold a person's weight (hence the need for a floor elsewhere) and that I'd go crashing through the bilge to the trailer below if I tried.
I'm totally not looking forward to crawling in there though.
Ahh it’s a necessary evil of inboard engine boats...I re configured my boats interior to make the seats easy to remove, in 10 min I can have it all out and then it’s wide open.
if you have a tight bilge and you’re a big guy just make sure you can get OUT, after you get IN! Don’t laugh guys have gotten stuck between engines!
