Hey guys,
I was removing the bottom end on my 1986 30hp Mariner this morning. I followed all of the instructions and went to loosen the shifting linkage nuts, the top one was pretty tight, so I sprayed it with PB Blast and came back later. When I came back, with minimal effort the linkage "broke" loose. I popped out the four bolts and slowly lowered the bottom end out. Once it was out, I realized that the "whole" linkage came out with the bottom end, instead of just the part where the two are supposed to come apart. The shifting linkage rod that came out has a small bolt through it with a clip through one side, two plastic washers, and then the rest of the bolt is gone. I assume I can replace the bolt, but how do I reconnect it back up inside the upper half of the motor? Any help or suggestions is greatly appreciated!
Here are some pictures I took of the piece in question: http://www.flickr.com/photos/97347455@N05/
Let me know if the photos don't work, or a better way to share them.
