Hy i have a 1986 model 115 stack 6 mariner that has just stoped firing on all cylinders. It has been running fine and cranking fine every time untill the other day. I usealy crank it once a week and let it run but sunday it wouldnt hit a lick and hasnt since. Ive checked the kill switch and unplugged the main harness to see if i had wiring isues in the boat but no luck. I could realy use some addvise as what to check for next. It seems like maybe the coils might be grounded out idk what wires to check that theory out. Any help would be greatly apritiated .. Thanks
