Welcome Guest - Sign Up today
No announcement yet.
Fuel pump / gas tank line problems with 2002 mercury 115 4 stroke efi
  • Fuel pump / gas tank line problems with 2002 mercury 115 4 stroke efi
    I am having problems with my Mercury outboard 115 4 stroke efi. She runs fine but looses fuel and I have to keep the primer bulb pumped to run. My question is can I run a small gas tank straight to the fuel pump and bypass the water seperator/ filter to see if that solves my problem?
    Re: Fuel pump / gas tank line problems with 2002 mercury 115 4 stroke efi
    Yes you can but I think you will wind up rebuilding the fuel pump.
    "A manual is a cheap investment"
    Fair Winds and Following Seas
    Bill
    PTC USN ret
    • #3
      Thanks for the reply. What is needed to rebuild the fuel pump? According to the diagram the only thing I would think needing replaced would be the diaphram I think it is #8 correct? Also is there somewhere I can get that at a good price? When I removed the top line on the fuel pump it wasnt spitting much fuel out at all so that is what I think the problem is too.
