It's on a 15 foot fiberglass cathedral/multi hull fishing boat. The boat used to do 20mph according to a GPS at top speed in smooth water. It stopped pumping water through the engine, don't think its clogged, maybe a bad impeller. Now it only does 13mph or so, and I'm guessing I toasted the motor.
I'd like to tear it apart, bore it a size over and get some new pistons for it, is there anything I can do to this motor while I'm in there (porting, bigger carbs, different reed cage, etc) to give it 10hp or more?
