vanderkool
- Oct 15, 2009
- 6
Last December I purchased a new Cypres Cay 20 foot pontoon with a 90 HP Mercury Optimax. The manual that came with the new optimax said the first hour change the rpm every two minutes. Then the next three hours run the RPM's between 3000 and 4500 changing every 10 minutes.
Once this was completed and at 10.5 hours on the motor, the motor gave up 400 RPM of operating engine speed at WOT. Dealer suggested 10 hours break-in period, but the manual said only four (the above mentioned).
Can anyone advise to where the manual says ten hours, because I did not see it anywhere?? What should I expect? Will I get the 400 RPM's back?
Update: Dealer claims that the 90 HP Optimax manual's break-in period definition is a misprint. I thought this was quite interesting seeing that the dealer claims that the outboard has not been properly broke-in after 65 hours of operation. Any advice??
