Update:
The above booklet, by Quicksilver, has been available for download, from my site, for a while.
I scanned two versions, one lo-res for browsing and one hi-res for download (for printing).
Those can still be found - along with a prop estimation spreadsheet
here and now Mercury has put the booklet up as well here.
Merc's is better for on-line browsing and can be printed - for high quality printing the download is recommended.
http://www.killcaremarina.com.au/index.php/everything-you-need-to-know-about-propellers.html
Everything You Need to Know About Propellers
In determining boat performance, propellers are second in importance only to the power available from the engine itself. Without the propeller's thrust, nothing happens. Your boat's propeller affects every phase of performance - handling, riding, comfort, speed, acceleration, engine life, fuel economy and safety. Like tires on a car, the propeller conducts the power from the engine to the "road". Your propeller is the primary connection between your engine and the water. Which propeller or propellers you select to make that connection is critical to achieving optimum boat performance. This article provides even the novice boater a solid understanding of propellers. However, some of the information presented here is also very technical. [h=2]BASIC PROPELLER PARTS[/h] The first step to understanding propellers and how they work is familiarizing yourself with the basic parts of a propeller. (Figure 2-1) [h=3] The maximum reach of the blade from the center of the propeller hub. It separates the leading edge from the trailing edge. B. Leading Edge That part of the blade nearest the boat, which first cuts through the water. It extends from the hub to the tip. C. Trailing Edge That part of the blade farthest from the boat, the edge from which the water leaves the blade. It extends from the tip to the hub (near the diffuser ring on through-hub exhaust propellers). D. Cup A small curve or lip on the trailing edge of the blade, permitting the propeller to hold water better and normally adding about 1/2" (12.7 mm) to 1" (25.4 mm) of pitch. E. Blade Face That side of the blade facing away from the boat, known as the positive pressure side of the blade. F. Blade Back The side of the blade facing the boat, known as the negative pressure (or suction) side of the blade. G. Blade Root The point at which the blade attaches to the hub. H. Inner Hub (Figures 2-2 and 2-3). The forward end of the inner hub is the metal surface which generally transmits the propeller thrust through the forward thrust hub to the propeller shaft and in turn, eventually to the boat. I. Outer Hub For through-hub exhaust propellers. The exterior surface is in direct contact with the water. The blades are attached to the exterior surface. Its inner surface is in contact with the exhaust passage and with the ribs which attach the outer hub to the inner hub. J. Ribs For through-hub exhaust propellers. The connections between the inner and outer hub. There are usually three ribs, occasionally two, four, or five. The ribs are usually either parallel to the propeller shaft ("straight"), or parallel to the blades ("helical"). K. Rubber Hub Rubber molded to an inner splined hub to protect the propeller drive system from impact damage and to flex when shifting the engine, to relieve the normal shift shock that occurs between the gear and clutch mechanism - generally used with low horsepower applications. L. Diffuser Ring Aids in reducing exhaust back pressure and in preventing exhaust gas from feeding back into propeller blades. M. Exhaust Passage For through-hub exhaust propellers. The hollow area between the inner hub and the outer hub through which engine exhaust gases are discharged into the water. In some stern drive installations using a through-transom exhaust system, this passage carries air. [h=3]Hub Configurations[/h] At the center of the propeller is the hub. If exhaust gases are discharged into the water through the hub, the propeller is called a through-hub exhaust propeller. If the exhaust gases are not discharged into the water through a passage in the hub, but rather over the hub, the propeller is called an over-the-hub exhaust propeller. This design allows the engine to wind up quickly as the propeller bites into water and exhaust. Top speed may improve due to the reduction in drag associated with the outer hub, but generally acceleration suffers slightly. The marine propeller draws or pulls water in from its front end through an imaginary cylinder a little larger than the propeller diameter (Figure 3-3). The front end of the propeller is the end that faces the boat. As the propeller spins, water accelerates through it, creating a jet stream of higher-velocity water behind the propeller. This exiting water jet is smaller in diameter than the actual diameter of the propeller. This water jet action of pulling water in and pushing it out at a higher velocity adds momentum to the water. This change in momentum or acceleration of the water results in a force which we can call thrust. Diameter is determined primarily by the RPM at which the propeller will be turning and the amount of power that will be delivered to the propeller through the shafts and gears. The degree to which the propeller may operate in a partially surfaced condition, as well as the intended forward velocity, will also play a role in determining the most desirable diameter. Within a given propeller line, the diameter usually increases for propellers used on slower boats and decreases for faster boats. If all other variables remain constant, diameter will increase as power increases; diameter will increase as propeller RPM decreases (slower powerhead or engine speed and/or more gear reduction); and diameter should increase as propeller surfacing increases. [h=3]Pitch[/h] When a propeller is identified as 13 3/4 x 21, it has a 13 3/4" (35 cm) diameter with 21" (53 cm) of pitch. Theoretically, this propeller would move forward 21" in one revolution. There are two common types of pitch: constant (also called "true" or "flat") pitch and progressive pitch (Figure 4-3). Constant pitch means the pitch is the same at all points from the leading edge to the trailing edge. Progressive pitch (also called blade "camber") starts low at the leading edge and progressively increases to the trailing edge. The pitch number assigned (for example, 21") is the average pitch over the entire blade. Progressive pitch improves performance when forward and rotational speed are high and/or the propeller is operating high enough to break the water surface. It is commonly used on mid- to high-horsepower propellers. Pitch is rather like another set of gears. For a given engine that wants to run at a given RPM, the faster the boat can go, the higher the pitch you need. If you select too low a pitch, the engine RPM will run too high (above the top of the recommended limit), putting an undesirable higher stress on many moving parts. You may have a great acceleration but your top speed will probably suffer and your propeller efficiency will definitely suffer. If you select too high a pitch you will force your engine to lug at a low RPM (below the recommended range) which is generally at a higher torque level and can be very damaging to your engine. Top speed may not suffer too much, but acceleration will be seriously reduced. [h=3]Rake[/h] When a propeller blade is examined on a cut extending directly through the center of the hub, as in Figure 4-4, the face side of the cross section of the cut blade relative to a plane that is perpendicular to the propeller axis would represent blade rake (Figures 4-5, 4-6, and 4-7). If the face of the blade is perpendicular to the propeller hub (Figure 4-5), the propeller has zero degree rake. As the blade slants back toward the aft end of the propeller, blade rake increases (Figure 4-6). With standard propellers, the rake angle varies from -5? to 20?. Basic propellers for outboard engines and stern drives commonly have around 15? of rake. Higher-raked (high-performance) propellers often have progressive rake which may go as high as 300 at the blade tip. Rake is either flat (straight) as shown in Figures 4-5 and 4-6, or curved (progressive) as shown in Figure 4-7. A higher rake angle generally improves the ability of the propeller to operate in a cavitating or ventilating situation, such as when the blades break the water's surface. With such surfacing operation, higher blade rake can better hold the water as it is being thrown off into the air by centrifugal force, and in doing so, creates more thrust than a similar but lower raked propeller. On lighter, faster boats, with a higher engine or drive transom height, higher rake often will increase performance by holding the bow of the boat higher, resulting in higher boat speed due to less hull drag. However, with some very light, fast boats, higher rake can cause too much bow lift, making these boats more flighty or less stable, in which case a more moderately raked propeller would be a better choice. [h=3] Cupping usually will reduce full-throttle engine speed about 150 to 300 RPM below the same pitch propeller with no cup. A propeller repair shop can increase or decrease cup to alter engine RPM to meet specific operating requirements on most propellers. For a cup to be most effective, it should be completely concave (on the face or pressure side of the blade) and finish with a sharp trailing edge. Any convex rounding of the trailing edge of the cup, on the pressure side, detracts from its effectiveness. Cupping is usually of little value on propellers used in heavy-duty or work applications where the propeller remains fully submerged. [h=4]Importance of Cup Location[/h] Using a round-bladed propeller as an example, if the cupped area intersects pitch lines, as in Figure 4-9, it will increase blade pitch. Cupping in this area will reduce RPM by adding pitch. It will also protect somewhat against propeller "blowout" (see Cavitation, below). If the cup is placed so that it interests rake lines, Figure 4-10, it then has the effect of increasing rake (see Rake, above). There is clearly some overlap where cup effects both pitch and rake. In some cases, adding a normal cup has reduced engine RPM by an unusually high number, as much as 1000 RPM. This "blown out," a situation not uncommon and often undetected until a cupped propeller is tried. A partially blown-out propeller has a mushy, somewhat unresponsive feel, and may produce excessive propeller spray. An accurate slip calculation (see Slip, below) can be beneficial here. Slip will generally jump from its normal 10% to 15% to over 20% for a partially blown-out propeller (on an average - to lightweight boat). Adjusting the cup on a cleaver-style propeller is more difficult. Since the trailing edge is very thick and runs straight out on a rake line, any adjustment will have far less effect on altering rake (Figure 4-11). The added pitch created by the cup can be reduced substantially by filing or grinding away some of the cup. At the same time, rake can be altered slightly. For less rake, decrease the cup in the area close to the tip. For more rake, reduce the cup in the area close to the hub. Obviously, any cup reduction will also result in an RPM increase. [h=3] To recognize a right-hand propeller, observe the prop from a position shown in Figure 4-12 (resting on either end of the hub is OK) and note that the right-hand propeller blade slants from lower left to upper right. A left-hand propeller will have the opposite slant-from lower right to upper left. The blade slopes or climbs up in the direction of rotation. A right-hand rotation propeller has the same basic blade slope as the threads on a common right-hand screw. Another method of recognition is to observe the propeller rotating in forward gear from behind the boat. A right-hand propeller turns clockwise; a left-hand propeller turns counter-clockwise. [h=3]Number of Blades[/h] A single-blade propeller would be the most efficient - if the vibration could be tolerated. So, to get an acceptable level of balance with much less vibration, a two-bladed propeller, practically speaking, is the most efficient. As blades are added, efficiency decreases, but so does the vibration level (Figure 4-13). Most propellers are made with three blades as a compromise for vibration, convenient size, efficiency, and cost. The efficiency difference between a two- and a three-bladed propeller is considered less significant than the vibrational difference. Nearly all racing propellers are presently either three- or four-bladed. In recent years, with the growing frequency of propellers being run at an increased height (surfaced), four- and five- bladed props have become more popular. They suppress the higher level of vibration and improve acceleration by putting more blade area into the water. They can also help to make the rake more effective in lifting the bow of the boat for added speed. Since there is only so much power available, blades should be as thin as practical (considering the strength of their material) because it takes more power to push a thick blade through the water than a thin blade. But what about the thickness variation from the leading to trailing edge? When viewing a common blade cutaway at a given radius from the center of a constant pitch-propeller (Figure 4-15), an approximate flat surface will be observed on the positive (pressure) side and a circular arc surface on the negative (suction) side, with the thickest point in the center. Edges usually are .06" to .08" (1.5 mm to 2.0 mm) thick for aluminum propellers, thinner for stainless steel. For propellers intended to run partially surfaced, as in racing applications, the "cleaver" blade shape (see Figure 4-14) is popular. Its blade section is usually a wedge. Blades with a thick trailing edge such as this should only be run surfaced. When they are run deep, where surface air can't ventilate the low-pressure cavitation pockets formed behind the thick trailing edge, they are less efficient. [h=3] For improved engine and boat performance, most propellers feature a hub design with a flared trailing edge or "diffuser ring." This assists exhaust gas flow and provides a high-pressure barrier that helps prevent exhaust gases from feeding back into the negative pressure side of the blades (Figure 4-19), which is another form of ventilation. [h=3]Cavitation[/h] As a shape passes through water at an increasing speed, the pressure that holds the water to the sides and back of the shape is lowered. Depending upon the water temperature, when the pressure reaches a sufficiently low level, boiling (i.e., the formation of water vapor) will begin. This occurs most often on a propeller near the leading edge of the blade. When speed is reduced and the pressure goes up, boiling will subside. As the water vapor bubbles move downstream into a high- pressure region that won't sustain boiling, they collapse (condense back to liquid). The collapsing action, or implosion, of the bubbles releases energy that chips away at the blades, causing a "cavitation burn" or erosion of the metal (Figure 4-20). The initial cause of the low pressure may be nicks in the leading edge, too much cup, sharp leading edge comers, improper polishing, or, sometimes, poor blade design. Massive cavitation by itself is rare, and it usually is caused by a propeller that is severely bent or has had its blade tips broken off resulting in a propeller that is far too small in diameter for the engine. (See Ventilation, above, for another common cause.) The cross section of a propeller blade in Figure 4-21 shows an example of one cause of cavitation. In this instance, a sharp leading edge produces cavitation and resulting cavitation burn as the bubbles condense further back on the blade face. Such cavitation burn can usually be corrected by repairing or rounding off the leading edge directly in front of the burn. Cavitation and cavitation burns can also form on the side of your gearcase. This will almost always be the result of a sharp edge directly ahead of the burn. Rounding off the sharp edge will usually eliminate the problem. [h=3]Angle of Attack[/h] To further understand how propellers work, it is important to appreciate the concept of "angle of attack." (This concept is also important in understanding propeller slip, detailed below.) To do so, it is helpful to compare how a propeller blade works to how an airplane wing functions. The wing of an airplane and its ability to carry the weight of the plane by providing lift is very similar to the spiraling travel of a propeller blade, which provides thrust. If a wing with symmetrical airfoil (Figures 4-22 and 4-23) is moved through the air so that air moves symmetrically above and below the wing, there is equal pressure above and below resulting in no "lift." The wing is said to be operating at zero degree (0?) angle of attack. With an angle of attack (Figures 4-24 and 4-25), there is a pressure change or difference above and below the wing which creates lift: negative (lower) pressure on the top and positive (higher) pressure below. Although it is clear that the airplane wing and the propeller blade move through air and water respectively, marine engineers prefer to talk about the situation in terms of the water moving into the blade. Allowed that freedom, consider Figures 4-26 and 4-27, which show the same angle of attack phenomenon, only in this case, for the propeller blade. To create thrust there must be some angle of attack or slip. The objective of propeller design is to achieve the right amount of slip or angle of attack, which is around 40, give or take a degree (Figure 4-30). This is accomplished by matching the right amount of blade diameter and blade area to the existing engine horsepower and propeller shaft RPM. Too much diameter and/or blade area will lower slip but will also lower propeller efficiency, resulting in reduced performance. Figure 4-29 illustrates this point. The conventional, sometimes called round-eared, blade type is that seen on most propellers (Figure 6-1). It has a rounded con?tour, has a slight amount of sweep back or skew and may be of a variety of shapes based on the type and application of propeller. It is designed to run fully submerged but can be run slightly surfaced with light loads in some cases. Weedless Propellers vary in their degree of weedlessness. That is, a cer?tain amount of weedlessness is designed into most propellers. But the blade type that is most weedless, and therefore classed as such, is a rounded blade with a high degree of skew; that is, the leading edge is swept back to a high degree leaving no weed-snagging leading edge projections (Figure 6-2). Even very weedless propellers can appear to be entangled in a ball of weeds which are, in fact, caught on the leading edge of the gear housing strut and torpedo. The rotating blades often create a tight weed doughnut wrapped around the forward end of the propeller's outer hub. Generally, these weeds will shed with reverse propeller rotation or, sometimes, a short burst of high-speed operation. A significant weed ball, however, can cause so much cavitation that it will prevent the generation of sufficient thrust to achieve planing. Cleaver "Cleaver" is a name applied for many years to a propeller whose blades have their trailing edge cut on a straight line, generally on a rake line (Figure 6-3). Often accompanying this blade shape is a blade cross section that looks more or less like a wedge; that is, the leading edge is very thin and sharp, while the trailing edge is the thickest point on a pitch line. This style is best suited for elevated engine installations which allow the propeller blades to break the water surface (called surfacing). |
