Good day,
I have 2018 Mercury 115 HP Pro XS 2.0 L (4 Stroke) who has always been maintained at the dealership at the end of each season and I have never had any issues.
I've put my boat in the water for the first time after winterization about a month ago and I experienced 3 beeps twice with reduced RPM while beeping. I took no chance and brought it to the dealership who basically did nothing other than plugging computer on it and let me now it did overheat. They checked a few things and let me know to try it again as it was perhaps false alarms. I was stunned and told them
i'm no expert but i'm pretty sure it will do it again... anyway tried it again this weekend with same results... i started looking for symptoms and noticed the following.
The return jet seems fine at idle but at medium or high speed it starts to come out sputtering and choking and within 30 seconds of sputtering is when I get the overheating alarms. I took the t-stat out and I experienced the same issue.
Does this seem to be a water pump issue to you ?
thanks !
thanks !
