Serial number 0G580734. 40ELPTO.
so long story story short. The motor would run for a while then lose all spark to all cylinders. I replaced the stator and switchbox. Engine fired right up on the hose. I replaced the fuel filter at this time. Took it to the launch. Ran it wide open to my dock. When I got to the dock. It did not want to idle unless throttle up to about 1500 rpm. I did notice a small amount of fuel around where the fuel filter clamps are on the fuel lines. I took the boat home and messed it some and it would idle on the trailer. I did replace the fuel line for the filter and reclamped it. Any idea on what I should be looking for?
