Hi folks - My duck boat motor sat for 4 years. Rebuilt carb (jets were plugged), soaked it, rebuilt bowl, float, needle valve. Can't get needle valve to seal when float rises? (New float, needle, copper seal & the 2 paddles are flat when turned upside down). Also top cylinder bleeds to zero on compression test after 1 min. When do wet compression test takes longer and pressure does not get any higher than dry test (120 psi). Bottom cylinder holds at 120 no problem. Starts then bogs down because gas is flowing out of carb air inlet. Any thoughts? Is this motor cooked? Thanks in advance for your help
