JohnyRingo
- Jan 9, 2019
- 5
I ran my boat low on oil in the summer of 2017. The boat gave me the beeping warning and I filled the main oil reservoir up with oil and the reserve reservoir with oil. I took my boat back out on the water a little later and the same thing happened, the boat's warning beeps went off and the boat went into limp mode and would not rev-up. I got home and called a boat tech and he told me about the low oil sensor needing to be reset. He had me unplug the sensor and plug it back in. I fired the boat up in my drive way with muffs and sure enough, the warning beeps went away. I then put the boat away for the winter.
So this past summer I fired up the boat on the lake and it kind idled like crap to where it didn't really want to run at all. I just figured it was normal coming out of winter and I tried to get the boat up on plane. It took for ever to get going and would not go above 3000 rpm. In hindsight, it was almost like it was in limp mode again without the warning beeps. I ran it all day thinking it was bad gas because it didn't want to idle real good. As I was ripping around the lake that day, occasionally it would kick up to 4000 rpm and then drop right back to 3000 rpm. At the end of the day while coasting into the dock, the rpm kicked up a notch so I took it back out for one more trip around the lake and it jumped up to 5000 rpm, so I thought that I had blown the bad gas out.
The next time on the lake, the same thing happened. I was back at 3000 rpm for a while. Then it would jump to 4000 rpm for a while, then back to 3000, then up to 4000. Than all of a sudden it went to 6000 rpm, so I thought I had my old boat back.
The next time on the lake, it started all over again...3000 rpm for a while, then 4000, then back to 3000. This time I couldn't get it back to 6000 rpm.
I was thinking it was the gas, but now I am thinking it is in-and-out of limp mode. Does anyone have any suggestions? It is a 2008 fuel injected Mercury Optimax 150. I have it back in winter storage right now and I have a guy who wants to buy the boat, but I don't want to sell him a boat with problems. The boat tech that helped me before is no longer in business and I am 100 miles from the nearest technician. My latest hunch is that it might have a bad battery. The battery is 10 years old, but I have never had a problem with it starting and no warning signs coming from the dashboard.
Thanks.
Thanks.
