Sylva-Ranger
- Jan 17, 2016
- 163
I want to check accelerator pump operation on a 2012 mercury 20 hp 4 strokes S/N 0R 509781
Put the serial number in this link and go to "carburetor " (sorry can't put the picture directly)
https://www.mercurymarine.com/en/ca/.../parts-catalog
If i remove the fuel bowl (20) , pump some fuel in the bowl and activate the accelerator pump plunger (30) by hand , that prime some fuel in a small hole directly in the bottom of the fuel bowl.
if i remember, usualy, instead of going out by this small hole when activate the plunger, the fuel is supposed to go out by the check valve ( 25) ?
And after that, the fuel that going out by this check valve is supposed to going into the ventury by a small passage ?
At this time, when the plunger is activate, the fuel simply return in the fuel bowl , not very usefull
if i'm wright , what can be going wrong ?
Also, on the part catalog above, they put an o-ring (42) near the plunger or near is spring …….I can't figure out where is this 0-ring …
I have the 2 o-rings (37) in the carburetor, but not the o-ring (42) .
Thank you !
Thank you !
