Tylerevenhuis
- Jul 14, 2018
- 11
Hello all. I just bought a pontoon with a 1987 60 hp Mariner outboard on it and it's not running well. Basically it's only running on the #1 (top) cylinder, misfiring on the #2 (middle) cylinder, and not firing at all on the #3 (bottom) cylinder. This motor is a three cylinder two carb motor, so I pulled the carbs and completely cleaned the bottom carb. It was quite clean to start with. But this didn't change how it runs at all. I checked spark and all the plugs are sparking well when held against the block. Wondering if anyone has any ideas to try next. I feel like this is ignition related because while it was running I adjusted the idle jet on the bottom carb and that didn't change how it was running at all either. Any help you have would be appreciated, thanks!
