Re: choke thermostat problem
Is this a divorced choke setup or an electrical operated setup? If it is a divorced setup, is there any options for the connecting linkage to allow for further throw? If it is an electric choke, have you verified that there is the correct voltage reaching the unit. If there are some compromised connections, the voltage, and therefore the current, will not heat it enough to make it work properly. Check for both supply and ground connections before discarding it. If it is operated off heat from the exhaust then it could be a setting adjustment. The has to be a reason for a factory choke to stop working properly. Find out why. There are rather simple in their design and usage.
