Menace53243
- Apr 21, 2014
- 5
I have a Bertram 33 repowered with Mercruiser 8.1. Fuel injected. The boat will start absolutely perfect, run fine and not miss a beat until 20 minutes of run time and then an engine will then starve for fuel. It will start slowly and then continue where the engine will then not run over 1700 RPM. The engine will run all day long at 1700 without missing a beat. Occasionaly I can bring back up to speed and it will run for a longer period of time. If I let the boat sit for some time, it will run perfectly until again 20 minutes into run time. I have the following done to the boat. Two marinas have worked on it as well. Scheudled now to check codes.
1. Fuel filters changed after only a few hours of running. dumped into glass jar and all is clear.
2. New fuel lines from pick up to fuel separator.
3. Fuel pick up has been taken out several times, cleaned clear.
4. Vent appears to be clean.
Thank you for reading.
