NO SPARK AT #1 an 7 plug, engine will not start
redz
Hi, my name is David, my boat is a Thompson Daytona 250. Engine ser:# oc536754, model mcm 5.7 litre ,V8 Alpha one
thunderbolt ignition
things I have done thus for, which are; check tachometer lead, check terminal connection at distributor. new ignition sensor, an distributor cap, new ignition coil, new battery ,new spark plugs, also a new ignition module.
please help will not start, will turn over but no spark at one an seven plug. use spark plug tester an volt tester, have 12v at coil, at battery , 12v going to ignition module thanks any help out there
thumpar
Re: NO SPARK AT #1 an 7 plug, engine will not start
Even with 2 cylinders down it should start but not run great. Have you checked firing order and tested spark at the plug?
Ayuh,.... Welcome Aboard,... Is it gettin' any Gas,..??
Bt Doctur
How experianced are you with the GM motor?
Was it running before all the work?
Could you have put a 6 cyl rotor plate in instead of a v8 one?
If you have spark on the other 6 leads and no spark on only 2 of then ,then check the spasrkplug wires
by swapping with a sparking cylinder.
tazrig
Try switching 2 spark plug wires that you know are good, if you still aren't getting a spark on just those two then change your spark plug wires. Or you could have a cracked distributor cap... rare but I've seen them be bad right out of the box.
NHGuy
Yes, swap the bad wires with known good. It does sound as if the wires are failed. BTW marine wires are longer that regular chevy ones. So if you find they are bad, or even if they are a bit old and brittle, get a set that's for your exact engine.
Then, for good measure, route them so they do not make contact with one another using ignition wire separators which are available at your auto parts store.
This eliminates cross firing and assures each pulse goes only to the right plug.
welcome aboard
in your list you never mentioned wires. did you replace the wires?
even on 4 cylinders, a V8 will run. so if your not getting spark on only 2 wires, it should still fire.
how strong is the spark?
as Bondo asked, are you getting fuel?
what is your compression?
redz
sorry I also replace all plug wires
redz
yes getting gas
redz
sparks are blue,purple
MikDee
Banned
Is it possible you're talking about cylinders #1, & #6, they are the opposing cylinders on the small block chevy, both being on TDC at the same time, with the cam, & distributor determining which one fires when. So, has the distributor been out of this engine, and put back in the wrong spot? Out of phase, then when it's supposed to be firing on #1, it will actually be firing on #6, and if is supposed to be firing on #6, it's actually firing on #1, appearing as though there's no spark on #1, & #6, when actually it's firing on the alternate cylinder.
NHGuy
Yup, good chance of MikDee having a finger on the issue. So recheck that #1 is firing when the #1 valves are closed on the compression stroke.
Bt Doctur
spark will occur no matter what the valves are doing.
MikDee
Banned
Not if the distributor is in 1/2 a turn off, you'd get no spark at #1 at TDC, and have spark at #6. The next engine revolution, you'd have spark at TDC on #1, and no spark at #6. This would be out of phase/time with the camshaft, if someone put the distributor in wrong.
Bt Doctur
No matter how you install a dist , you will have spark produced every time the points open or the cutout passes past the sensor. Says only #1 and #7 don't have spark. He never got back to answer the trigger wheel question either.
Plus he`s never responded to what work he had already done on the motor.
thumpar
It may not fire but it still would have spark.
