youknowmeasbud
- Dec 3, 2013
- 25
so, ive read in other threads that there is 3 different places to drain the water from the block. i have only found 2.. there is one on the port side of the block just above the oil pan (brass plug), then one on the underside of the exhaust manifold (petcock style) and cant seem to find another one...
i started with the one on the port side above the oil pan.. maybe got a couple gallons out.. didnt count.. then found the petcock on the manifold. opened it and nothing came out, so i remove the whole plug to, then reemed it out but got nothing from it.. hoping that everything came out..
so..
have i removed enough water to allow any possible expansion from freezing or am i forgeting something?
so..
