I have a 2000 4.3 mercruiser mpi with a balancing shaft.
I need help solving the issue I'm having trying to adjust the valves on my mercruiser. Below is the background on the motor.
There was salt water infiltration in the motor (pistons/crankcase) which cause the motor to locked up. The motor had a lot of rust in it. I pulled the heads and had a stuck intake valve, replaced it, took apart the roller rockers and cleaned them, cleaned everything that I could get at, replaced exhaust manifolds.
I put everything back together and torqued down the valves to 20 ft/lbs. When I went to start the motor and wouldn't start and seemed hard to turn over. I then loosened the valve nuts to zero lash and then started the motor. It started up and then adjusted the valves wile the motor was running. The problem is that the nuts loosen up after a few minutes. Then I tried to tighten down the nuts until the motor starts to stall then back the nut off. The nut still wants to loosen up. This scenerio doesn't happen to all the valves but probably four of them. The oil coming out of the push rods only squirts out of on or two push rods and oozes out of the rest this is at 800rpms. (The motor has run for a total of 30 minutes so far). Oil pressure 38-40PSI
I'm leaning to a problem with the lifters. I didn't soak them in oil when I cleaned them. I only coated them.
This very frustrating and looking for any advice before I guess and replace the lifters.
Thanks
Thanks
