achris
More fish than mountain goat
- May 19, 2004
- 27,468
This post contains Videos I have made. I will continue to add as I make new ones...
Setting up the bearing pre-load on later Alpha Ones, Alpha One gen II, and Bravo drives
Servicing the water pump impeller in 1966-1991 (MC-1 to Alpha One) drives.
Removing Alpha Drive
Checking Engine Alignment
Installing Alpha Drive
Alpha Drive Shift cable adjustment
Alpha I Gen II water pump service (Part A) Added 7/11/2013
Alpha I Gen II water pump service (Part B) Added 7/11/2013
Gimbal Bearings explained Added 30/11/2018
Uni joint removal (without butchering the drive!) (Added 5/Sept/2019)
Marine vs Automotive. Fuses. (added 9 March 2020)
Shift Spool Wear Test Video. (This is not my video, but it is very good...)
Chris.....
Chris.....
