Juniorcarp
- Jul 23, 2011
- 18
I have 99 SeaRay Alpha 1 gen2 5.0 with efi what is the normal temperature i should see while running i currently run 170 @ all speeeds and 175 at about 4000 rpm is this normal ?
I rarely run for extended periods at higher than cruise speed
I installed a 160 Tstat if i remember correctly this spring .
Had the impeller done this spring and changed the circulating pump also changed the two sensors at the thermostat housing !
He DID replace his impeller...apparently unsure about the T-stat.
I don't know what the problem is...170/175 is NOT too hot.
Even though I did the impeller last season when I get my bellows done this year I will have the housing and impeller changed again for 110$ part Ill do it cooked heads are no fun I went through that already !
Are those two sensors the same? I'm assuming they are both temp switches, but I'm not 100% sure. Thanks.
