trailshredder
- Apr 25, 2011
- 283
Just got my 76 Merc 140 back together, new head, gaskets, spark plugs, rebuilt carb and rebuilt 19 degree prop. This is my first ever boat so I am not really sure what to expect out of it. Just seems like it should have a little more ?umph? than what it does, although, how do you measure ?umph?! It will do about 35, downwind, full throttle at about 4100RPM. Occasionally will miss at full throttle and stall at idle which makes it a real pain trying to trailer it at the ramp! I have turned the idle up now (900-1000 RPM) to keep it from dying out and adjust the 2 idle/air mixture screws to the smoothest idle out of the water. Wondering if the valves need adjusted again after running a while?
