Diagnostic port location Mercruiser 5.0 MPI
the man
2004 Mercruiser 5.0 SN OW003759 with Bravo 3 SN OW108118.
Newbie bought the Rinda Technologies diagnostic tool. All excited to use it. Cannot find the port to plug it in. I looked through both manuals (Engine and diagnostic) and they just have wiring diagrams, which are not helping me. I stared at the engine for too long. Crawled all around. I gave up.
I know I will feel stupid and possibly blind when I finally find it but oh well, where is it?
Re: Diagnostic port location Mercruiser 5.0 MPI
Ayuh,... Look inside the steel box mounted to the portside manifold...
Fun Times
His engine is to new to have the "steel box".;):)
Newport Dave had the general idea of what to look for in the second post down. http://forums.iboats.com/showthread.php?t=284123
The connector may have a white sticker/tag around the wire harness next to the plug that say's depth sounder on it.;)
The data link connector (DLC) is a 4‑pin circuit for attaching the diagnostic tool to the ECM.
The DLC is located on the port side of the engine next to the oil filter. Before attaching a
diagnostic tool to the engine, verify that the key is off and the pins are clean of corrosion
and debris. Pin A is the 12‑volt ground connected to the engine harness at splice 104. Pins
B and C are data retrieval lines from the ECM. Pin D is the 12‑volt supply to the diagnostic
tool.
IMPORTANT: Diagnostic tools can only receive data with the key on or engine operating.
Diagnostic tools need a minimum of 9.5 volts. If the diagnostic tool does not respond, verify
the connection, verify that the key is on, and check the battery voltage.
A malfunction of the data link connector will not set a fault.
The four wire colors are going to be, Purple, White with Purple, White with Black, & Black.
Good luck with it.:)
Don S
Thought I would add this from the manual for future reference.
attachment.php
