Mercruiser backlash rod length DIY?
Feash
I made a home made version of the mercruiser backlash indicator rod tool PN 91-53459. I didn't want to wait for one to arrive. Now I only need it for before & after comparison after changing out a few parts in the lower gear unit. For future use, I want to be able to compare to the specs. Would someone who has one of these tools be so kind as to measure the distance from where the edge of the drive shaft is to the I mark so I could place a mark on mine? The other marked distances may some day be helpful also. Thanks
teamwork
Re: Mercruiser backlash rod length DIY?
I also want to make a DIY version. Nobody here who knows the distances?
Ayuh,... For what outdrive,..??
Don S
It's for all Merc outdrives. it has 3 marks on it.
For less than 15 bucks, you can buy one.
Don S
Thank you sir. Hope you don't mind, but I added inch dimensions to your drawing for those that don't know metric.
attachment.php
