94 merc.3.0LX "looking for carbie kit"
danyboy
engine #of269456. transom#of322098. And the numbers I took off of the carb are #05924A1-3X01 ( just under fuel inlet pipe)will this be the same as a 3310-805924?? And does anyone know if this is the carbie that came on boat new ?? or is it a replacment carbie,ect??? thanks,Dan.
danyboy
Re: 94 merc.3.0LX "looking for carbie kit"
well what Im finding out from reading blogs is my carb is a mercarb because it only has one mixture screw( rodchester has 2 ) so do i need to disasemble carb. to find out if i have straight acc.shaft or the shaft with 90 degree bend???one site is telling me I need kit#3302-804845 for shaft w/o bend or kit#3302-804844 w/bend?? is the acc.pump shaft the only diffrence between them?? thanks,dan
danyboy
ok guys after a lot of research this is what i came up with!!!!!Mercruiser Mercarb Rebuild Kit
Sierra #18-7098 or #3302-804844
Mercarbs can be identified by the single adjustment screw in the carb base (as opposed to 2 adjustment screws used on Rochester 2 barrels).SIERRA 18-7098 This kit is for the Mercarb that has an accelerator pump with a 90 degree bend. If your Mercarb has the straight shaft accelerator pump,then you want the Sierra #18-7097 or #3302-804845
Replaces Part #: Mallory Marine 9-37612, GLM76086
Fits the Following Mercruiser Applications:
Hp/Model Serial # Year
120 Hp (GM 2.5L, 153 cid, Inline 4) 0A492056 - 0B531853 1986
2.5L (GM 2.5L, 153 cid, Inline 4) 0B531854 - 0C853255 1987 - 1989
140 Hp (GM 3.0L, 181 cid, Inline 4) 0A484073 - 0B450800 1986
3.0L (GM 3.0L, 181 cid, Inline 4) 0B450801 and Up 1987 - 2004
3.0LX (GM 3.0L, 181 cid, Inline 4) 0C856559 - 0K999999 1990 - 1997
165 Hp (Merc 3.7L, 224 cid, Inline 4) 0B434941 - 0B774251 1987
170 Hp (Merc 3.7L, 224 cid, Inline 4) 6916779 - 0B434940 1985 - 1989
3.7L (Merc 3.7L, 224 cid, Inline 4) 0B774252 and Up 1988 - 1989
175 Hp (GM 4.3L, 262 cid, V-6) 0B527955 - 0B773242 1987
4.3L (GM 4.3L, 262 cid, V-6) 0B773243 and Up 1988 - 2004
200 Hp (GM 5.0L, 305 cid, V-8) 0A482027 - 0B774444 1986 - 1987
5.0L (GM 5.0L, 305 cid, V-8) 0B774445 and Up 1988 - 2004
5.7L (GM 5.7L, 350 cid, V-8) 0F601000 and Up 1996 - 2004
5.7L MIE (GM 5.7L, 350 cid, V-8) 0L002003 and Up 1998 - 2004
5.7L Ski (GM 5.7L, 350 cid, V-8) 0F775200 and Up 1996 - 2004
Fits the Following Mercruiser Carb Numbers:
1389- 9562A1 3304- 9565A7 3310-861448A1
1389- 9563A1 3310-805924A2 3310-864940A01
1389- 9564A1 3310-806077A2 3310-864941A01
1389- 9670A2 3310-806080A2 3310-864942A01
1389-806077A2 3310-806972A1 3310-864943A01
1389-806078A2 3310-807312A1 3310-866140A02
1389-815396A2 3310-807504A1 3310-866141A02
1389-815397A2 3310-807764A1 3310-866142A03
3304- 9565A1 3310-861245A1 3310-866143A03
HOPE THIS SAVES YOU GUYS ALOT OF LOOKING AROUND....
slag
If you buy that Sierra kit at NAPA, SIERRA 18-7098, it is superseded by part number SIERRA 18-7098-1, which basically means they changed nothing but now the kit costs $65.99 plus tax instead of 59.99.
I just bought one and put it on my mercarb and it appears to work well. Wish it came with new jets, but those are separate. It does have a powervalve though.
Has anyone found where you can buy just the float bowl gasket? I could use 2 or 3 of those.
