RedRock2020
- Jun 12, 2020
- 5
Troubleshooting stall at idle for sterndrive Mercruiser 3.0 s/n 0w3055xx. It has the Delco EST. ('05 Bayliner 185 bowrider).
Boat idles fine and then will shut off randomly. Would normally start up and last 2 times out it would drive fine for a half hour at least and then stall only under idle and then super hard time starting twice. The other stalls hard start but it would start.
-Last time I had trouble starting I started to open the carb at the fuel inlet and heard what sounded like it sucking fuel as soon as I broke the seal and then I got fuel (I thought maybe no fuel to carb, loosened the fitting at outlet on fuel pump and fuel was definitely under pressure on that side). Thinking possible closed float, rebuilt the carb last year. Just installed a brass float today and have not tested.
Most of the idle stalls it restarts without issue. The stall is weird in that it is a clean shutoff without much if any stutter. Boat runs great at low-mid-high throttle. Boat can idle for 30 seconds to 20 minutes and then stall or idle for a half hour and not stall. Seems to only happen when engine is warmed up.
- Delco EST, it appears the that one of the "points" might be grazing the pole piece and slightly uneven. I did replace the rotor and distributor cap and no change.
I ordered a Peltronix coil and ignition. I thought it would be easy to install per some of the other posts but I guess they meant conversions from a points ignition. I don't see how the pole piece and the coil come off so I can install the Peltronix.
I would appreciate some advice on how to proceed. The distributor shaft appears to be in great shape. Should I scrap the Delco EST and go with Pertronix or not? Advice on how to fix would be great. Spending entirely too much time in my boat in the garage and not on the water.
Background, last year same issue and some lag throttle issues (just bought the boat 2 years ago and it didn't work right from when I bought it except the test drive). Took to mechanic he corrected timing and not sure what else, not much though and no parts installed other than filters and fluids. Mechanic said it runs great. Ran great for about 3 hours of engine time. I just changed the anti-siphon valve as well. When I got it from the mechanic it fired right up and now it takes 10 seconds with throttle to start. It's all within 2 boat outings.
