The exhaust hose on my MerCruiser inboard motor failed and I am replacing it. There are two pieces of 3” hose with an elbow in betweenl and I had no problem installing the new hose pieces to the elbow and one end to the tea. The final step is connecting the 11 inch piece of hose to the exhaust manifold. Here I ran into a problem. I spent several hours trying to get the hose on to the end of the exhaust manifold, with no success. The hose is the hard rubber with wire reinforcement (the same as what was previously there). It is almost as though the outer diameter of the manifold fitting is larger than the inner diameter of the hose. Can anyone suggest a way to get this hose onto the manifold fitting? I am physically and mentally exhausted from this seemingly easy project! Thanks in advance.
