76SeaRay
- Aug 24, 2017
- 1,047
Is the sea water pump (mounted to the side of the engine) only used for the closed cooling systems or is it like an option on the standard cooling system? Just trying to decide if I need one since the closed systems are so expensive I will just run a standard cooling system.
Thanks....
Thanks....
