just purchased a 1980 Tahiti day cruiser inboard/outboard. It has a 95 vortec 5.7 converted to a carburetor and a first generation alpha outdrive. I just took it out for the first time and runs and drives fine except when I get up to around 3000rpms under a load it makes a loud knocking/chattering/pinging(?) noise. Sounds like a cracked or lose flexplate or the sound of a fan on a truck hitting the fan shroud. But I thought I ask before I pull motor. If I adjust trim up or down, it seems to effect how soon it makes the noise. And the slower I climb in rpms the longer it takes for the noise to come on. If I slowly ease into it the noise will not come in until close to 4k, that's with trim all the way down. And with trim up some it will come on as early as 2700 rpms. And the noise doesn't slowly come in. It's instant. And does not go away until I throttle down. Doesnt make the noise at all in neutral ethier. This is my first boat and it was my first time ever driving a boat lol. I've built lots of Chevy trucks from the ground up and know my way around a Chevy motor pretty well but never dealt with one in a boat or a boat all together. I live in northern AZ and it gets well below freezing so I can't just hook it to a hose without winterizing it Everytime.
And the local lake is way to cold to get wet and was frozen over last time I drove by there. So I gotta drive over 2 hours to test it on the lake....I'm just wondering does this sound like it could be a loose flywheel, or damper? Or cv or gimble bearing about to come apart? Next time I try it I'm goin to try and replace fuel pump, and fuel filter/water seperator. I'll have a timing light too so I can check timing and advance. I'm hoping it's just some detination and timeimg is off. I also just installed a pertronixs electronic ignition and removed the points. But I didn't drive it with the points or any time prior. It has a yl Mallory distributor. Is there a way to check the timing advance without running the motor and useing some type of tool and removing the cap? Thx
