I have a non running Mercruiser 4.3 EFI from 2001 - the engine turns over fine, there is spark, but no fuel, so it seems like a fuel pump problem.
I have checked all the fuses and tried swapping the relays (which I can hear clicking) but I can't hear the fuel pump running.
Next step is to check the pump is getting power, but I can't get to the pump. Am I right in thinking the pump is inside the fuel cooler underneath the port manifold and that removing the riser and manifold will give access?
Any other suggestions for things to check before starting to dismantle everything?
Thanks for your comments and suggestions.
