bortSanders
- Sep 10, 2019
- 11
350 MAG
serial: 2A191167
2014 SeaRay Sundancer 260, bravo 3
600 hours
rental boat
Won't rev past about 3400 rpms. Won’t plane out, Sounds like the rev limiter kicks on and stumbles. No alarms or any indication of problems on the gauges. I am able to recreate the problem with the boat parked in the slip, drive in neutral.
I caught up on past due maintenance in an attempt to fix the problem:
-correct plugs NGK 5599, OEM Cap Rotor Wires, Water separating Fuel filter (old one about ½ dark-not that bad)
-Batteries are new, clean tight connections
no change
-prop was bent and has since been replaced, no change
I did find a small chafed leak in the vacuum hose from the fuel pressure regulator (elec taped for now), but I figure that should be a low rpm prob not a high rpm prob.
- Fuel pressure at the schrader valve test port between the 2 fuel rails and behind the throttle body: idle = 36-37psi , vac hose of fuel psi regulator removed 46-47 psi. Also the prob occurs with the fuel pressure regulator vacuum hose removed too. Its a MAC tools fuel gauge and I've really only used it a few times, so it should be accurate.
Hooked up Rinda scantool on the laptop:
- I checked for codes: none active. except the "SWITCHED BATTERY VOLTS" code 65 times in the previously active section. I assume thats one of those things you ignore. I might add that this is a rental boat.
-I made a video snapshot of the Parameter Data if anyone can help. The fuel trim at the top right of the screen isn’t visible, but it's equal to the other banks fuel trim. It also has audio to hear the problem.
- note: I also have a noise at idle that I dismissed as valve train noise, but I made a video just in case anyone thinks its a bigger issue...(its the second link)
Any help is very much appreciated. Thank you. No need to sugar coat things.
parameter data:
noise at idle:
serial: 2A191167
600 hours
rental boat
no change
parameter data:
noise at idle:
