I found a post from a while back (think it was from chrisa) on the procedures for setting the trim on an Alpha one Gen 2. It had these two pages. I'm stuck on the first step :facepalm: . It says "rotate the sender until the needle is at the bottom of the arc". Does that mean using the control on the shifter/throttle (I'm guessing it must, because there really is no other way)? When I try to trim down, nothing happens. I have both the trim limit switches off the outdrive right now. Could it be that they are set in the down position already, which is why when I trim down, nothing happens?
