rickasbury
- Jul 13, 2011
- 756
So, had done the bellows and gimbal chasing a water leak (bellows was not the problem) and getting it back on the water. Couple of short runs addressing a power steering pump and bugs after pulling the motor and getting there. Did a test run last weekend and started hearing a tick...thought it was a lifter but found as I turned the steering, it went away. I'm going to grease the bearing and the coupler and give it another try. I recall when I put the bearing back in ( which is the older version you grease through the zert) aligning was kind of a mystery but assume I got it close as it did accept grease? I think I used grease I bought at the merc store but don't recall it was specific for that...so if you grease...is the grease getting distributed to the bearing or do you need to bump the motor to get it spread around? I would think it would go into the race and as it fills just come out the face?
