This weekend's update:
I performed part of the fuel test.
At idle there is about 2" Hg draw on the fuel tank. I don't know why, but I didn't think to try it at a higher RPM.
If I pinch off the tank side the draw increases to 15 or 16 " Hg for at least 20 seconds, although it probably took 20 seconds to climb that high.
I am still working on a way to measure pressure at the carb.
I tried base timing mode, No change
I tried unplugging the knock sensor, No change
I sprayed soapy water all over the distributor, and looked for a short around the distributor and sparkplug leads. nothing visible or audible.
I removed each sparkplug lead one by one, and cleaned them with soapy water, and reinstalled. They were a little oily, but otherwise no damage noted, and now they are dry and clean. No change.
I cleaned the grounds where the knock sensor, wiring harness, and other major grounds are tied to the Motor. They looked fine, but in any case, no change.
I tested the ignition sensor one more time, this time while totally cold. in one direction it measures open, in the other it measured 9.5 Megaohms.
Yet to do
- Measure the pressure at the carb
- Replace cap and rotor, will arrive this afternoon
- Possibly try an alternate tank feeding the pump/or try measuring the vacuum at a higher level than idle
Questions
- Can I measure spark plug lead resistance effectively?
- Is there a rev limiter for the Thunderbolt V that is lower when the motor is not loaded
- The reason I ask is that it acts a lot like a rev limiter is hitting
- The same day I brought it back from the lake it seems like it was having a hard time at a lower RPM, maybe 2800 or 3k, but now it is consistent at 4k. At the time I thought it was an improvement, but not solved. Now I'm starting to wonder if I fixed it but I'm just hitting the rev limiter while unloaded. I really need to get it in the water, but I can't seem to get there. Maybe I'm just loosing my mind.
As always thoughts and opinions are appreciated.
